make sure the valve that controls the hot/cold opens and closes letting water flow through the heater core.
check the operation inside at the controller and make sure the same is happening under the hood or dash (where the valve is). |
Let's move this to General Rodding Tech.
Dan
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
Looking under the dash I can see the temperature wire move as I adjust it and I can feel a difference in how hard the air blows, but no difference in the air temp. I did this while the engine was running for about 15 min.
I also felt the hoses again and they were cold except right by the water pump. |
Your problem is that the waterpump is where the cold coolant from the rad enters the engine. You need to move the hose from the back of the pump to the spot where the coolant sensor is. Put the sensor in the side of the drivers side cylinder head where it belongs, you will have heat then.
With the hose at the waterpump you are c circulating the water from the radiator to the heater core. The coolant has no heat in it there. You need to tap it from the area next to the thermostat. If you were to loop the hoses from the water pump to the fitting on the intake and eliminate the radiator fitting, your heater would work sooner as the engine would warm up faster as the coolant would not circulate through the radiator untill the thermostat was opening The heater would also work better as a result too Last edited by latech; 12-19-2010 at 01:35 PM. |
wow, so stupid how that was overlooked. It didn't really occur to me until you explained it, latech.. obviously you want hot fluid running into the core but for some reason in my head it made sense to get the fluid from the water pump. Anyways, thanks man
Thats OK, the return side from the heater is in the water pump as is the return from the radiator (lower hose)any place else is good for hot water!
| Recent General Rodding Tech posts with photos |
| time for some more heat! what do you think of this heater? | smithkustoms | Garage - Tools | 15 | 02-03-2010 10:45 AM |
| Need help deciding on garage heater | Xenocide | Garage - Tools | 20 | 01-05-2008 09:54 AM |
| flex-a-lite mojave heater | elcaminodragster | Interior | 6 | 09-25-2007 01:44 PM |
| no heater | runn141 | Engine | 21 | 09-05-2006 06:07 PM |
| Heater has mysteriously stopped working. | HotRodMan | General Rodding Tech | 8 | 12-29-2003 04:38 AM |
