Heater/air condition unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2013, 09:20 AM
Bobs36ford's Avatar
Last journal entry: Video of new upholstery
Hi
The heater control valve in my vintage Air/Heater is not working.After engine warms up ...heat continues to come out. I installed a heater control valve outside under the hood to cut off water flow before it reached the unit. Believe it or not after engine warmed up heat continued to come out. The water supply line was HOT on both sides of the control valve. Go figure!
Bob
Old 06-02-2013, 01:01 PM
Where did you install valve? Should be in the hose coming from the intake.If it is in the one from the water pump that is the return line.
The Following User Says Thank You to 46streetrod For This Useful Post:
Bobs36ford (06-03-2013)
Old 06-03-2013, 08:55 AM
Bobs36ford's Avatar
Heater/Air
You're right......I did install on water pump side. Thank you for advice ...I'll change it right away.
Bob
Heater/air condition unit Bobs36ford Projects/Builds/My Ride 2 05-23-2013 12:39 PM
2001 silverado air condition help 68ss Electrical 15 12-09-2011 03:14 AM
What are they called? Ice air condition??? jimcar-9 Hotrodding Basics 8 07-06-2010 09:01 PM
air condition unit 58 TINKER58 Hotrodding Basics 1 07-11-2005 08:59 PM
camaro heater and air condition Dreadlord General Rodding Tech 0 12-01-2003 02:52 PM
