Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Heater Cables
Thread: Heater Cables
Old 10-24-2003, 05:53 AM
Shortstep Shortstep is offline
Gettin a life..Goodbye
Here's another tip that I use- If your replacement cables don't have the plastic covering that covers the old spring looking outside you need to lube them good with wd-40 or some other kind of soaking oil and slip a piece of heat shrink over the entire length of the sheath and heat it up. Chances are you'll never have to mess with it again.
