-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Heater Cables (http://www.hotrodders.com/forum/heater-cables-26290.html)
Travelinman 10-22-2003 05:12 PM
Heater Cables
My son's friend has a 1970 Buick Skylark. When he bought the car the heater did not work, I looked at the system 1 of the cables was cut and the other is frozen. I looked through Hemmings and called a few places only one said he would call back, but never did. Does anyone have any ideas?
It is a heat only car no AC.
jwcnj45 10-23-2003 03:40 PM
Don't know if it will help you but this company makes custom built cables. www.push-pull.com I have not dealt with them but have one of their catalogs. They claim to be able to make any type of cable you need.
Travelinman 10-23-2003 05:04 PM
Thanks...I'll give them a shot. :thumbup:
scottgto 10-23-2003 08:00 PM
Did you try www.yearone.com ? They have almost everything.
poncho62 10-23-2003 08:03 PM
Go to the junkyard ahd get a couple of cables and replace them.
Shortstep 10-24-2003 05:53 AM
Here's another tip that I use- If your replacement cables don't have the plastic covering that covers the old spring looking outside you need to lube them good with wd-40 or some other kind of soaking oil and slip a piece of heat shrink over the entire length of the sheath and heat it up. Chances are you'll never have to mess with it again.
