Heater fan motor stays running - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2009, 10:11 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I have a '97 Ford F-150. This morning I went to get in my truck and the fan motor for the heater was running. At first I thought I had left the ignition switch on, but that was not the case. Then I noticed, with the ignition switch on, that the warning light for the airbag was lit up. This warning light goes out when the ignition is off. If I leave the blower on, it runs no matter if the ignition switch is on or not. Anyone run into a problem like this before?
Old 10-25-2009, 10:24 AM
Wiki Edits: 31
I think they use relays instead of resistors for the control, the high might be stuck on.
Heater fan problem grapro Electrical 5 09-03-2008 09:48 PM
Need advice on a good electric fan set up. Streetmaster Engine 13 01-07-2006 02:37 PM
? about an electric fan for PU. Streetmaster Engine 8 08-20-2005 10:14 PM
electric fan or clutch fan?? mancinator Engine 4 06-02-2004 02:49 PM
Fan Clutch-or-no Fan Clutch, When An Why ALASKAN Engine 6 05-23-2004 09:55 AM
