Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Heater for Garage
Old 12-27-2004, 10:07 AM
pmeisel's Avatar
pmeisel pmeisel is offline
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
Heating calculations
From www.mcmaster.com
1) Surface area of enclosure (total sq ft. of walls, floor, ceiling)
2) Heat loss factor. 25% well sealed and insulated, 75% sealed but not well insulated, 125% neither well sealed or insulated
3) desired change in temperature fahrenheit
Multiply for BTU/hr
In your case 936 sq ft x 25% x 40 degrees (pretty toasty) = a little over 9000 BTU
From another HVAC site if you are forced air heating and ventilating:
1) Cubic feet of enclosure
2) Air changes per minute
3) 1.08 (constant factor for energy to heat air and time)
4) desired change in temperature fahrenheit
Multiply for BTU/hr
Second formula more useful if you are painting, heating a public space that requires ventilation due to cooking, smoking, etc.
Hope this helps
