Originally Posted by MYRIDE
All good advise Dusty and thanks. I have already designed it with "cheater trusses" over a portion (12') and a wall height of 10' on a stub wall of 12". This will give me a midspan of 13'10" (2" below the 14' bylaw) allowing the use of a hoist. Attic trusses over the remainder for storage. Spoke to a pipe-fitter that will be doing my gas line and he also assured me of the safety and wide usage of this type of plumbing (who knew?). 60,000 BTU Radiant heater should do it. Regarding the "Blue Roof-mate". Is it available locally i.e Rona etc?
Thanks again, Ken
Ken , roofmate is a trade mark of dow corning I believe....it is the high density styro board...usually colored pink or blue, most building suppliers and lumber yards carry it...it has an insulating factor of R5 per inch of thickness...a 1" thick layer is sufficient...you do want some heat transfer into the earth below slab at any rate so that the ground always remains fully thawed during the winter heating season to preclude frost heave of the floor...so too much insulation is not a good thing...
as for a poly film moisture barrier below the insulation, what really works great are the reinforced plastic shipping tarps that are covering the skids of lumber that stores get....they are really strong and durable....much better than rolled poly film....and best of all, they are free!!....just ask the shipper at rona, home depot, totem or any lumber yard....they toss them out in the trash....
also, a very good way to get a lot of storage space in a small building is to run 4 foot wide pallet racking along one or both walls....then you can have a mezzanine ....deck the upper beams with 3/4" plywood....leaving a headroom height workspace below....
last tip....there are a lot of poor concrete finishers around...try to find a really good one that does large warehouse floors so you get a nice result....the average guys doing home garages usually arent too good....you can find out who the good finishers are by asking the concrete truck drivers....they see the results every day...or go around some construction sites and look at the pours being done...
dont overlook having the finisher trowel in hardener into the surface (comes in bags, applied by throwing on to surface as it is power trowelled)....a minor additional expense but well worth it as the surface will not chip if you drop something heavy on it ....on hammer something on it...
and ask the finisher to give you a polished finish and to spray on a good grade of commercial quality sealant on last....it soaks into the green concrete and then you will never have a problem with oil stains or surface degradation and dusting....
as for grade of concrete, pay a bit more for strong mix....go for the equivalent of 5,000 psi (not sure what the equivalent MPA is, ask the redimix folk)....
and go for a min. 6" average thickness floor....a typical 4" garage slab is too thin...especially if you have a hoist in mind one day....
as for reinforcing, I went with 1/2" rebar on 12 inch centers when I did mine...that was commercial code at the time...
if you are planning a grade beam on perimeter as you mentioned, I would pour the beam and then frame in and roof the structure....then I would pour and finish the floor later so that it is shaded from the sun for a good slow cure without surface crazing....
a good floor is very important in a shop....
good luck....Ian
