Heater hose bulkhead - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2010, 09:15 PM
I need a bulkhead for my heater hoses, preferably polished aluminum. My car has no air so I am having trouble finding something for just the 2 heater hoses. Everything I found is for cars with air. Anybody seen one of theses somewhere? Thanks.
Old 03-24-2010, 10:12 PM
302 Z28's Avatar
Jegs has them
Vince
Old 03-25-2010, 06:09 PM
Hey thanks, i checked summit and speedway with no luck.
Old 03-25-2010, 07:42 PM
cboy's Avatar
Last journal entry: Finished
Or if you are into making your own, you can take a look in my journal for one way you might do it.
I made my bulkhead by massaging some copper fittings to fit.
I then used a normal after market chrome hose kit (below) to connect to the block. I made the "dress up ring" shown on the left in this picture from a short length of aluminum tubing.
Here is how the bulkhead looks from the engine side of the firewall. The arrow notes a small copper ring soldered to the end of the bulkhead to prevent the hose from popping off.
And with the hose kit connected.
And finally, a shot of both hoses connected up to the bulkheads.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 03-25-2010, 09:12 PM
That looks really good, great idea thanks.
correct heater hose routeing for BBC diamond mike Engine 3 11-02-2009 06:21 PM
small block chev. heater hose routing stanjr41 General Rodding Tech 3 06-01-2009 11:11 PM
Braided fuel hoses all leak gas vapor odor? Steve S Engine 2 04-26-2007 09:52 AM
routing heater hose on SBC! need ideas bigfred1958 Engine 1 02-18-2004 05:06 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
