heater hose routing - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2011, 02:06 AM
heater hose routing
84 gmc 2wd pickup, 86 383 stroker. Do the heater hoses hook to the radiator at all or do they run from the pump through the core back to the top of the intake manifold. There is a nipple on the radiator but I dont know what it is for. I have my hoses routed like this. From the top of the intake manifold throught the core and back to the nipple on the side of the radiator near the top. This doesnt seem right because It seems like the thermostat is being bypassed some what. The heater works fine, almost too good. And the engine temp alaways is real low at the 1/4 mark on the gauge. I think I need to reroute the hoses,so the engine temp comes up to make it run better. I heard that if a motor runs too cool that can mess with performance just like a motor too hot can hurt it. Thanks TJ
Old 09-18-2011, 07:07 AM
Barry.M's Avatar
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project-For Sale
Wiki Edits: 3
G'day task65,
Normally heater hose outlet is at the manifold near the thermostat, and return back into the water pump somewhere near the bottom radiator hose.
If your setup has the return hose joining the top radiator hose, that would work also, and probably better than the above setup IMO. Yes it would bypass some of the hot water/coolant which may not be an issue. Just depends how hot your ambient temperature in summertime is, which may cause an issue. The fact that your current setup takes water/coolant from the inlet manifold and puts it back into the top radiator hose is just the same as if there were no bypass through the heater core. With your current setup you would be putting back somewhat colder water/coolant than would ordinarily be flowing direct from the inlet manifold through the top radiator hose and radiator.
As far as your gauge reading only a 1/4, my suggestion is to buy an accessory mechanical temp gauge and fit that for accurate readings. Or check the radiator water/coolant temp directly with the radiator cap off (naturally cap removed very carefully to avoid burns) with a stick thermometer. Ideal temperatures are arround 160-190F, depending on smog equipment. Anything less than about 140F should be avoided as it is commonly thought to increase engine wear on the bores particularly and excess sludge buildup throughout the motor.
If temps are low, what you could do is place a restrictor in the heater hose to reduce flow through it. This will reduce the amount of hot water/coolant flowing to your heater. You can also fit a ball valve in the heater hose line at a convenient spot, which can be manually opened and closed or partially closed for some temp. variation.
Hope this helps you out.
Cheers............Barry.
Old 09-18-2011, 08:30 AM
My '75 GMC has the heater hose routed back to a fitting on the radiator, and that is the stock setup. I have also seen GM heater hoses routed to the water pump, but I have a plugged fitting on top of the water pump.
The 1/4 scale reading may be okay. I have the stock sender and gauge, and also a mechanical sending unit in the intake manifold. At 200 degrees on the mechanical, the stock electrical gauge is just hitting 1/4 scale. I have also verified the 200 degree reading with an infrared thermometer on the thermostat housing. In moderately hot weather, my SBC stabilizes at about 200, using a 195 degree thermostat, and I think that is where i want it.
Bruce
Old 09-18-2011, 08:45 AM
SSedan64's Avatar
Does your Truck still have the Heater Control Valve> http://www.rockauto.com/catalog/moreinfo.php?pk=161462 these block water flow thru the Core.
Many Truck with A/C or HD cooling route the return back to the Rad tank.
My 71 Cheyenne w/AC & 4-core Rad does. Has a Vac operated Shutoff valve.
Old 10-19-2011, 12:15 PM
runn141's Avatar
SB S10
which is better? from the water pump to the heater core back to the radiator? or from the intake to the heater core back to the radiator?
Old 10-19-2011, 01:30 PM
SSedan64's Avatar
The Ports on the Water Pump are Intake ports.
So from Intake Manifold to Heater Core & return/back to the Radiator or Water Pump is correct.
small block chev. heater hose routing stanjr41 General Rodding Tech 3 06-02-2009 12:11 AM
Brake hose routing Q staleg Suspension - Brakes - Steering 4 03-12-2009 01:59 AM
Heater hose routing and hangers? Jag Daddy Engine 1 04-07-2004 04:22 PM
routing heater hose on SBC! need ideas bigfred1958 Engine 1 02-18-2004 06:06 PM
vaccum hose routing help? pleeze mikeweyman Engine 3 07-04-2003 03:33 PM
