Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Heater hose routing and hangers?
Old 04-07-2004, 03:22 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
I typically use two hose clamps (the type with the metal strap wrapped in vinyl and with the screw hole in the ends), one around each hose with a single bolt through the holes in both clamps. This makes a neat way to both clamp and separate the hoses.
