Heater hose routing and hangers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2004, 03:16 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
I have to run my heater hoses around the engine compartment to the heater box on the drivers side. Right now I'm using wide wire ties to hold them together and to keep them in place on the firewall etc. Is there a better solution? Something like a hose separator block or??? I'm worried that the vibration will cut into the hose and cause it to leak.
Regards
Mark
Old 04-07-2004, 03:22 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I typically use two hose clamps (the type with the metal strap wrapped in vinyl and with the screw hole in the ends), one around each hose with a single bolt through the holes in both clamps. This makes a neat way to both clamp and separate the hoses.
