Heater Hose Sizing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2010, 04:25 PM
Heater Hose Sizing?
OK, anybody used 1/2" heater hoses instead of the more common 5/8" or 3/4" ones?
Reason I ask is that I want to route heater hoses on my Ranchero "down under" alongside the oil pan and then back up to the firewall. Using 1/2" (-8) hoses would make it a bit easier and neater. As the cabin on this car is pretty small, I'm guessing that there might be enough flow with the smaller hoses..
thanks,
Old 12-24-2010, 06:13 PM
That makes me go hmmmmmmmmmmm never thought about it. I can't imagine that there would be a problem, but then again, why do they make it 5/8 or 3/4?
One way would be to use metal tubing, the outside diameter would be smaller than the 1/2" rubber with the inside at 3/4 or so.
Old 12-24-2010, 06:36 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Makes me go Hummmmmmmm also Brian, But they do make automobile 1/2 inch heater hose and the adapter also to go from 3/4 or 5/8/ to 1/2 . I don't really see a problem either but never thought about it till i seen this thread.
Cole
Old 12-24-2010, 06:54 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
the only problem i can think of, is your heater wouldn't blow as hot if the fan was on high.
the rear heat in the wifes 4runner is feed by some pretty small lines!
i think it should work ok.
Old 12-24-2010, 11:15 PM
Thanks for the thoughts. The OEM setup had twin steel tubes on top of the engine with hoses on either end. Going down and under in a tidy manner would mean winding the plumbing down around the alternator area. Just think that using -8 hoses would make the job a little nicer. IIRC, those steel tubes were pretty small diameter and one of the coolant ports on the engine is 3/8" NPT, which would seem to be a flow restrictor in itself.
Old 12-24-2010, 11:17 PM
my 86 astro van had an auxillary heater in the back seat.. it was fed with 1/2" steel pipe....
Old 12-26-2010, 03:16 AM
bentwings's Avatar
bentwings
I think you could use 1/2 inch hoses with and adaptor at the core if need be. I thought about it just recently but went with #10 AN fittings on the water pump and 5/8 hoses. I should have thought harder. I had to make a special wrench to tighten the fittings. Now I have another tool to carry with my in an already overstuffed tool box.
I have driven in 15 deg weather but I still only use 2nd speed on the fan so there is plenty of heat. I don't even have a head liner yet.
Old 12-26-2010, 08:51 AM
Well, the word from St. Paul counts for a bunch, especially as it concerns heaters!
Old 12-27-2010, 10:09 AM
1971BB427's Avatar
I'm running 1/2" heater hoses on my hotrod and no problems at all. Lots of heat.
Old 12-27-2010, 10:13 AM
eloc431962's Avatar
Wiki Edits: 37
The proof is in the pudding.
Cole
Old 12-27-2010, 10:36 AM
A Mexican Socket Set wrapped in masking tape does the job nicely.. (that's an adjustable wrench to most people)
Old 12-27-2010, 12:10 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
For the most part, you can use whatever lines you want. Depending on the engine, some use the heater core as the thermostat bypass and restricting flow may or may not cause it to overheat just a tad before the thermostat opens.
Most engines have a built in bypass under the thermostat or in the water pump, and in that case you can use 1/8" hose if you want It will just give the heater core less heat
Heater hose bulkhead lt1tyrell General Rodding Tech 4 03-25-2010 09:12 PM
heater hose old dog 1 Hotrodding Basics 4 10-10-2009 09:47 AM
Heater hose Connectons fosterdl Engine 2 02-09-2008 01:36 PM
What is this in my heater hose? (Picture) Ghetto Jet Engine 10 11-16-2004 11:15 PM
Heater Hose Killer 41chev Engine 15 01-27-2003 08:16 PM
