Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Heater Hoses/Firewall Problem
Old 02-18-2005, 02:45 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
It sounds like the inlet has broken loose from the heater core. The only real way to fix this is to remove and fix the core. You could probably cobble up a temporary fix with the silicone, but it sounds as though it's been leaking a while and you really don't know what the core itself is like.
I don't know if you can remove the core without removing all the heater housing from the firewall. That involves almost removing the fender. When ours came loose we had the entire front end off.
I would also recommend you check your front passenger floor for damage.
