Heater Hoses/Firewall Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2005, 10:17 AM
EazyDuzIt102's Avatar
1965 Impala SS Convertible
Hey everyone.I got a 1965 Impala SS and I am having a problem the the lower heater hose on the firewall.I started the car the other day and I noticed that the bottom hose was leaking.So I went to tighten the hose clamp on there and noticed that the part coming out of the firewall(That the hose connects to)was really loose.The stuff holding it on there was rotted out.How do I fix this?It looks like they just put a bunch of silicone around it to keep it sealed because the hole in the firewall is bigger than the the part the hose connects to.Is there something I can buy so it will fit properly or am I suppoed to just put silicone around it and stick it back in?Someone please help.Thanks,
Eazy
Old 02-18-2005, 10:45 AM
I dun learned sumthin
Your heater core is probably rotted out. Not to hard to replace or if you don't use your heater you could just remove it entirely. Normally accessed under the dase or could be through the front cover.
Old 02-18-2005, 10:58 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
heater hose
Rtv works well and is easy to remove.
Old 02-18-2005, 01:45 PM
MI2600's Avatar
Member# 3287
It sounds like the inlet has broken loose from the heater core. The only real way to fix this is to remove and fix the core. You could probably cobble up a temporary fix with the silicone, but it sounds as though it's been leaking a while and you really don't know what the core itself is like.
I don't know if you can remove the core without removing all the heater housing from the firewall. That involves almost removing the fender. When ours came loose we had the entire front end off.
I would also recommend you check your front passenger floor for damage.
Old 02-18-2005, 02:40 PM
I had a similar problem with my '64. I replace the heater core, it was leaking at that stub out. On the '64 you access it from under the dash and was a pretty simple deal. I bought the replacement through NAPA. I don't remember the cost, but do remember that it seemed reasonable.
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
Temperature Sending Unit problem Centerline Engine 3 11-12-2004 05:13 PM
Overheating problem slik Engine 7 09-16-2004 06:59 PM
Jumping the heater core hose...is it ok Adrenaline_Fiend Engine 8 06-02-2003 04:00 AM
painting in garage... water heater concerns? Eddie N Garage - Tools 18 03-09-2003 08:06 AM
