heater for my truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2013, 10:29 AM
brotherskeeper's Avatar
And a country boy can survive
heater for my truck
OK... got a 55 f100 I'm planning on getting a heater for it. Not really sure where to start. I'm not looking for a/c just some heat for winter. I would really like a kits of some sorts. I did some searching but couldn't find any websites just for a heater kit. Any info or leads y'all can point me to?
Josh
Old 10-12-2013, 10:32 AM
vinniekq2's Avatar
what does your truck have in it now? Do you have a heater motor?
Old 10-12-2013, 10:43 AM
No sir, its got nothing in it. I'm having to start from scratch. It doesn't have to be anything fancy. Just need some heat.
Old 10-12-2013, 11:04 AM
vinniekq2's Avatar
WOW!
maybe start with a water control valve.(basically a tap control to allow water to flow full or partial through a hose into the interior)I would go to a wrecker and look at Nissan or other impoerts that donot have A/C
They have very compact systems.you could get by with the heater box/motor and manual air control valve.adapt a hose to your defrost vents.If something fits your application,Buy A NEW/REBUILT heater core for that application.
The water valve will need a cable to control amount of water going to heater core(ie;temperature control)
heater motor needs a switch (variable if motor is variable speed)
Make sure you wire in system and use an inline fuse.
bigger heater core will allow more heat.
go to a local rad shop and see what they have to offer,both parts and ideas
The Following User Says Thank You to vinniekq2 For This Useful Post:
brotherskeeper (10-12-2013)
Old 10-12-2013, 11:17 AM
RWENUTS's Avatar
You could bite the bullet and go for the whole thing!
Heat, defrost and air.
Buy once and done!!
http://www.summitracing.com/parts/vta-74053-lfu-a
OK, I'm understanding all that. Good info, thanks for the help. I one stupid question though??? Where would I tap the heater water hose to the motor to get the hot water?
Old 10-12-2013, 11:26 AM
Buy once and done!!
Yeah I feel ya..... turn-key. Maybe so......
RWENUTS's Avatar
Here's a cheaper one and likely no hoses to run.
Heater Craft HEATER KITS FOR ON-ROAD & OFF-ROAD VEHICLES - JCWhitney
The Following User Says Thank You to RWENUTS For This Useful Post:
Old 10-12-2013, 11:32 AM
Yeah!!!! That's what I'm looking for!! Perfect! Well done. I looked and looked..... thanks
Old 10-12-2013, 11:45 AM
RWENUTS's Avatar
I googled '53 ford heater kits'.
Bingo!! Bango!!
Old 10-12-2013, 01:55 PM
techinspector1's Avatar
Wiki Edits: 326
You need a factory service manual....
1954-1955 Ford Pickup & Truck Repair Shop Manual Reprint
This is a re-print of the original factory service manual.
Old 10-12-2013, 02:16 PM
Irelands child's Avatar
Also, Vintage Air make a couple heaters.
Irelands child
Old 10-12-2013, 04:38 PM
Heater
Check this out.
Flex-A-Lite 640 Mojave Universal Heater - Speedway Motors, America's Oldest Speed Shop
heater not working in truck...switch maybe? boatanchors Electrical 4 10-04-2008 05:29 PM
chevy truck heater box wrangler Electrical 6 06-15-2007 10:17 PM
53 ford truck heater & Air Rodzing Interior 4 04-28-2005 10:16 AM
Ideas & Opinions : Placement of Truck Heater & AC Units horvath Interior 26 02-10-2005 02:51 PM
I NEED A HEATER! BstMech Hotrodders' Lounge 10 02-08-2003 06:46 PM
