Heater problem turn to engine problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2011, 11:00 AM
I got a 92 nissian pathfinder a few mouths ago the ac/heater and rpm meter and all dash lights started randomaly going out. everything else worked radio headlights speedometer and it still ran i didnt look into it because a hit to the dash would kick it back on.
this morning when i started my car heater/rpm/dash would not kick back on and when i gave the car gas while the headlight were on it died. about and out later got it cranked up agian and i could drive it but if i turned headlights on it start dying
any ideas??? i really dont have the money to take to mechanic so any advise would help
Old 10-29-2011, 11:18 AM
35terraplane's Avatar
problems
Sounds like you have a good short going, it's hard to say where it is, you will have to take a look at your fuse panel first as you have so many things going on. Then use a meter to check for things that might be grounded. I know nothing about a Nissan but that will be a start. if you know nothing about electrical on a car, this might take awhile.
Bob
heater problem jasrking General Rodding Tech 6 10-11-2009 02:31 PM
heater problem untchable502 Electrical 10 10-01-2008 03:23 PM
Heater fan problem grapro Electrical 5 09-03-2008 09:48 PM
Heater line problem HELP Bart General Rodding Tech 4 02-01-2007 07:25 PM
heater problem Stu1985 Electrical 1 11-29-2004 07:56 AM
