Heater Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2013, 11:56 PM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
Heater Question
I have a 72 Chevelle. The heater fan doesnt work I guess. I flip the switch to high, low, medium.....nothing. I feel a little heat coming out of the defroster, but nothing powerful. Any suggestions other then the blower motor?
Anyway to check wiring or fuses?
Thanks,
Mike
Old 02-10-2013, 06:17 AM
If you can get to the connector for the blower motor, just put a test light on it and see if you have voltage when you switch on the heater. If you have voltage and the motor does not move, you need a motor. Good news - they are not expensive.
No voltage at connector - you may have a bad blower resistor pack or a bad dash switch. However, usually when the resistors fail you still have high speed. The resistor is mounted inside the heater plenum near the motor, and it will have 3-4 wires.
How it works: High speed is a direct connect to full 12 volts. For lower speeds the resistor pack switches in combinations of resistors. The resistors are ceramic and often break when they get old.
If your car has A/C there may be a separately fused 12 volt line for the high speed blower relay. The power line often runs across the back of the firewall, and it has an inline fuse holder.
Bruce
Old 02-10-2013, 06:33 AM
Wiki Edits: 27
power and ground.
I just went thru that with my ranger, corroded connections at the relay. On some wiring systems, the ground is switched thru the resistors. .I had power at the blower but it didn't run. to test your motor it's best to Jumper feed 12 V and use a ground wire.
Old 02-10-2013, 08:01 AM
T-bucket23's Avatar
Wiki Edits: 26
Bruce
Also check the all important ground.
Chet
Old 02-10-2013, 06:02 PM
EOD Guy's Avatar
X2 on the ground, had one that had 12v to motor, motor wouldn't run....... jumper the motor and it runs...... ended up being a dirty ground..... I found this out by touching a good ground wire to the motor body and it ran....... cleaned the mounting points and it was fixed.
heater core question... cutthroatkid General Rodding Tech 0 11-22-2009 09:55 PM
53 pickup heater question 53deluxe General Rodding Tech 3 12-08-2007 06:54 PM
heater question pat63chevy Engine 1 11-26-2007 05:53 PM
Aftermarket A/C & Heater question bnewsom General Rodding Tech 8 01-28-2006 01:54 PM
Heater core question Jag Daddy Engine 1 01-24-2004 11:11 PM
