Heating/cooling question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2008, 05:53 PM
el pollo's Avatar
It's shady under this tree...
Hey all, I have a question in regards to my wife's 2000 Ford Windstar.
Over the winter I noticed that the front heater stopped working. The blower works, just no hot air. The rear heater works fine.
Today I recharged the air conditioner, and noticed that the rear vents are blowing cold air, but the front is not. Again, the blower works fine, just no cold air.
The Haynes manual is absolutely useless in answering my questions. My guess is maybe a blocked duct. Could there be something that I am missing?
Old 04-02-2008, 07:08 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
If there is air blowing from the vents.....
Blend door actuator for the front would be my guess. It could be stuck in the middle meaning it's drawing air from both the heater and evaporator cores. A quick check would be to run the A/C from a cold start while monitoring the vent temperature. If it blows cool (cooler than outside ambient temp) and slowly gets warmer as the engine warms up, this is would indicate the blend door. If you have automatic climate control (ability to set temp rather than just hot or cold), pull the fuse to the control panel for a few minutes then replace and see if that helps.
Old 04-04-2008, 06:33 AM
el pollo's Avatar
Sweet. Thanks for the info, because my assumptions were base around what you just said. But before I end up removing the dash (I am literally afraid that I'll blow off an airbag!) I wanted to seek some advice from you all.
Again thank you for your time!
Old 04-05-2008, 10:39 AM
Big Don's Avatar
ac and heat
Bad vac motor or vac control line manifold falling apart....
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
