-   -   heating problem (http://www.hotrodders.com/forum/heating-problem-224723.html)
rockytop57 10-06-2012 01:23 PM
heating problem
heating problem, have a 48 plymouth with an 87 sbc and trubo trans, new engine and trans. new northen radiator. put 15" 6 blade solid fan on to. idling will set there at 170 to 180, start driving and it heats up and will keep going up. changed thermostat still the same. any ideas. tried every thing i can think of.
frank sieber 10-06-2012 02:04 PM
Had a friend put wrong rotation water pump on before. Just saying.
T-bucket23 10-06-2012 02:22 PM
What is your timing set at. Retarded timing will cause overheating at higher rpm. Also could be hoses collapsing at higher rpm. Do you have springs in the hoses. Are you running a shroud, if not the air could be going around the radiator.
techinspector1 10-06-2012 02:27 PM
Quite a few of us have contributed to this wiki article, maybe you can find some help by reading through it. There are so many variables to the cooling system that you need to be a detective to figure it out.....
http://www.crankshaftcoalition.com/w...cooling_system
rockytop57 10-07-2012 08:37 AM
thanks for your help, timing is 4 degrees btdc like book says, lower hose has no spring, and have shroud but not on yet, will be today.
T-bucket23 10-07-2012 09:37 AM
I would push the timing up to at least 12 BTDC. 4 is way to low. Also you should check to see what your total timing is. If you are not running a vacuum advance it should be in the 34-36 range all in by about 2800 rpm.
I would also get a lower hose with a spring in it.
After you fix the timing take it for a ride and see if it improves.
These are just the basic items, there are a lot of things that can cause overheating but you need to start with the basics. The fact that it doesnt overheat at idle does eliminate a few items.
Get back to us on the progress
rockytop57 10-07-2012 09:51 AM
fixing to head to shop to try, thanks for the help. have a tach coming and can check rpms
rockytop57 10-07-2012 10:03 AM
also i do have vaccum advace
cdminter59 10-07-2012 01:38 PM
heating problem
Here is an article on HEI distributors. It explains setting the different stages of your timing too. http://www.crankshaftcoalition.com/w...EI_distributor
T-bucket23 10-07-2012 01:53 PM
Make sure you set the timing with the vacuum advance disconnected
John long 10-07-2012 03:22 PM
Be sure and set timing! 4 deg is way too low for sbc. Will cause heating. At 4 deg you should be experiencing low power to boot.
