Had a friend put wrong rotation water pump on before. Just saying.
| The Following User Says Thank You to frank sieber For This Useful Post: | ||
rockytop57 (10-07-2012) | ||
What is your timing set at. Retarded timing will cause overheating at higher rpm. Also could be hoses collapsing at higher rpm. Do you have springs in the hoses. Are you running a shroud, if not the air could be going around the radiator.
Artificial Intelligence is no match for Natural Stupidity Chet |
| The Following User Says Thank You to T-bucket23 For This Useful Post: | ||
Quite a few of us have contributed to this wiki article, maybe you can find some help by reading through it. There are so many variables to the cooling system that you need to be a detective to figure it out.....
http://www.crankshaftcoalition.com/w...cooling_system |
| The Following User Says Thank You to techinspector1 For This Useful Post: | ||
I would push the timing up to at least 12 BTDC. 4 is way to low. Also you should check to see what your total timing is. If you are not running a vacuum advance it should be in the 34-36 range all in by about 2800 rpm.
I would also get a lower hose with a spring in it. After you fix the timing take it for a ride and see if it improves. These are just the basic items, there are a lot of things that can cause overheating but you need to start with the basics. The fact that it doesnt overheat at idle does eliminate a few items. Get back to us on the progress
heating problem
Here is an article on HEI distributors. It explains setting the different stages of your timing too. http://www.crankshaftcoalition.com/w...EI_distributor
Make sure you set the timing with the vacuum advance disconnected
| heating problem at cruise speed | Icelander | Engine | 4 | 09-10-2008 06:45 PM |
| Over Heating Problem | 2000jack | Engine | 5 | 07-25-2006 06:36 AM |
| Downhill heating problem | bstoelting | Engine | 6 | 05-24-2006 02:07 PM |
| Possible Over-heating problem | Missing Link | Engine | 10 | 08-05-2005 10:19 AM |
