Heating question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2006, 04:54 PM
Heating question.
Ok this isnt for a hot rod its just somehtign i dont knwo how to fix and need to get fixed. Ok my girlfreind has a 1996 mercury cougar. Now the problem is the heater wont really work. Like she'll turn it on full blast and it will barely blow. it does a very little bit but not like it should be doing. So i wanna know whats wrong if anyone knows. Is It a fuse?. the blower?. is it going to be expensive to fix?. if it is a fuse how is it possible to tell if its blown?
Old 10-21-2006, 06:31 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I have had to replace the blower motors in my 94 & 97 Birds.
I have the auto climate in both of them, if the brushes get weak or worn in THIS system that could happen
Not too hard to fix---remove glove box and there it is.
Same blower for both the auto and manual systems.
If the blower is spinning okay-----check for this
PLASTIC BAG GETTING SUCKED UP INTO THE INTAKE
Happened to me
All in all---not too bad to repair----about $40 at Auto Zone/PepBoys/ etc.
Bryan
Old 10-21-2006, 07:14 PM
30desoto's Avatar
Dodge ain't all bad
Also, you may want to check your vacuum lines to your heater to see if your vents are opening properly, if you listen to the fan and it sounds like it is running good but still no air this can be the vents are closed.
30dee
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
