Heating Tape - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2002, 09:26 PM
Harlequin's Avatar
Post Heating Tape
Does anyone have any idea where I can get my hands on some 12volt heating element tape? I've seen tape that is AC; just not DC...Here's basically what I need to do. If anyone is familiar with VW motors if you do not have the heat riser tubes connected in the winter the intake manifold will freeze to the ID of a pinhole in a few minutes. I was told by a few people that my only solution do to the fact that my mufflers don’t support heat riser tubes is to heat my manifold other then using the motors heat. I came up with the idea of using Heating Element tape, I’ve seen this stuff used before on pipes in houses and things…if anyone has even a general direction in where I can go with this it would be greatly appreciated..
[ December 07, 2002: Message edited by: Harlequin ]</p>
Old 12-06-2002, 09:31 PM
axle bastard's Avatar
you're killin me buck!
Post
i have seen simaler (sorry about the spelling)
stuff in the electric motor industry, don't know the opperating volts though, hope that helps
Old 12-07-2002, 07:13 AM
4 Jaw Chuck's Avatar
Post
McMaster Carr has this stuff, two pages of it! Just do a search in the left pane for "heating tape".
— Han Solo
Old 12-07-2002, 12:42 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Don't you just love the McMaster Carr catalog? second best is Grainger. I can read them for hours!
[ December 09, 2002: Message edited by: willys36@aol.com ]</p>
Old 12-07-2002, 07:26 PM
Harlequin's Avatar
Post
I think that link will do that trick...thanks guys!
Old 12-07-2002, 10:08 PM
E.T. divided by $ spent= Speed
Post
What about running 110volt AC heat tape plugged into a AC converter box runn off the altenator???
Old 12-08-2002, 09:26 AM
Harlequin's Avatar
Post
Hey Monte, that’s exactly what I’m going to do. I’m going to but an inverter just big enough and run the AC stuff. It seems that the DC tape is almost non-existent. The only DC stuff I found was in the UK. And shipping from there is a nightmare.
Old 12-08-2002, 04:17 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
I don't know about the type driven off the alternator, but the ones that just plug into the cig lighter or hook up to a power source. Say not to use them with anything with a heating element (blow dryer/heater etc.)
Old 12-08-2002, 08:20 PM
Harlequin's Avatar
Post
Ohh thats conferting...I think I might just make a phone call to the company in the U.K. that makes a wrap for veedub maifolds thats DC... <img src="confused.gif" border="0">
Old 12-08-2002, 08:37 PM
Post
I can't remember Ohm's law but measure the resistance of the tape,have someone figure the amperage draw at 120volts.I dought that a foot or two of heat tape will pull more than the converter box can handle.They say not to runn any heating elements like toasters,hotplates,etc... cause they have the lowest resistance and draw the most amperage.
Use the cut to length tape,that you put the ends on yourself.
One thing to consider befor attempting this is if the heat tape burns and energizes the chassis you have line voltage electifying your vehicle.Not good especially on a rainy day.So becareful.
Old 12-08-2002, 08:55 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
The warning that came with my inverter said not to use these items because it inverts/amplifies the voltage through a modified sinewave. I'm no electrical engineer, but the warnings were written in bold writing. You make a good point about the risk of using this setup. I think I would use the DC type instead, especially if they were made for this application.
Old 12-09-2002, 12:28 PM
Madd Syntst's Avatar
Returning American Maddman
Post
You are right about those catalogs. can sit at my desk and do "research" on different material I never knew existed!
