Heating urethane - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2005, 06:36 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Heating urethane
Whats the scoop on force drying urethane?
I thought I saw somwhere that you shouldn't get
it to hot when heating the panel after spraying.
Is there a temperature of the panel that I shouldn't exceed?
Old 10-27-2005, 07:43 AM
In a booth its usually 140 for 45 minutes. Depends on the clear.check the tech sheet. Thats different then putting it in the sun. I have put panels in the summer sun and checked them with an IR thermometer and the panels have gotten around 120. But i have seen the sun do some weird things to fresh paint when trying to force dry.
Old 10-27-2005, 09:13 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
I thought it was around 130... If the bake booth is 140, metal temp should be around 10 degrees cooler
Matthew
Old 10-27-2005, 05:46 PM
Actually with Diamont they say surface temp 140 for 45 min. So we set our booth at 160 to achieve a surface temp of 140.
Enamel vs Urethane vs Polyurethane???? MARTINSR Body - Exterior 11 07-02-2011 07:58 PM
Epoxy vs Urethane Primer UKLuge66 Body - Exterior 41 11-23-2008 06:50 PM
Urethane Bumper repair ??? 1ownerT Body - Exterior 1 10-03-2005 04:44 PM
Urethane and Epoxy Primers bmech211 Body - Exterior 1 04-17-2004 06:04 AM
Urethane Bushings - Yes or No?? Jim Weeks Suspension - Brakes - Steering 5 05-01-2002 09:12 AM
