heavy duty - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2008, 08:47 PM
Thumper_Pumper's Avatar
muddin maniac
Last journal entry: moter
heavy duty
if any of u herd of my c15 cat swap into a 72 chevy than u no wat im dealing with here and i wanting to know wat kind of shocks and coil springs i would need for all this weight
Old 05-06-2008, 05:50 PM
The Maintenance Geek
How much weight??
K
Old 05-07-2008, 09:36 PM
muddin maniac
id say 14000
Old 05-07-2008, 10:19 PM
powerrodsmike's Avatar
Wiki Edits: 161
Originally Posted by Thumper_Pumper
id say 14000
Is that what you think the total weight of the truck would be?
The Caterpillar website lists the c15 motor by itself at 3050 pounds.
https://ohe.cat.com/cda/files/448363...e%208.9.07.pdf
later, mikey
BE different....ACT normal.
Old 05-07-2008, 10:40 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Heck, might as well put a the 72 on a single rear axle truck chassis. That way you can still pull a 35000 lb trailer.
Old 05-10-2008, 02:00 PM
muddin maniac
do u think it would fit? cause im sure i could find one
Heavy duty universal relay for electric fan? KNanthrup Electrical 8 04-06-2007 01:32 PM
heavy duty suspension 53belair Suspension - Brakes - Steering 14 01-15-2007 01:16 AM
1991 olds 88 heavy duty air conditioning fan polarity and position fumplet Electrical 3 08-30-2006 02:54 PM
Ford's Super Heavy Duty Transmission Capacity sum87mustang Transmission - Rearend 1 04-12-2003 03:33 PM
heavy duty t5 & a 383??? solowookie Transmission - Rearend 4 11-19-2002 09:12 AM
