Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Heavy duty vs Regular Duty
Old 10-17-2012, 10:24 PM
pricesgarages's Avatar
pricesgarages pricesgarages is offline
use the regular on the 1-2 use washers to bring the 3-4 flush with the pin with the plate drilled and pressure regulator spring it will shift firm at heay throttle stock tires on a vortec will bark on the 1-2 at wot but it will be comforable at part throttle use a corvette piston and a .500 boost valve
The Following User Says Thank You to pricesgarages For This Useful Post:
abbazabba (10-22-2012)
