-   -   Heavy duty vs Regular Duty (http://www.hotrodders.com/forum/heavy-duty-vs-regular-duty-225118.html)
abbazabba 10-17-2012 07:42 PM
1 Attachment(s)
I just don't know which spring will be best.
These two springs are out of a 4L60E Superior Shift Reprogramming Kit. (see pictures)
Heavy Duty and Regular Duty is all the info I have.
Can anyone give me some comparison in shift characteristics in the two?
98 Chevy K1500
5.7 350
4L60E
It's no hot rod but I would like it to tow occasionally.
Has anyone used one of these in a similar set up?
Thanks
SSedan64 10-17-2012 08:13 PM
I'd go with the Firmer HD Accumulator spring for firmer 1-2 shift. On the 3-4 I wouldn't, don't use 4th gear when Towing unless the Trans is upgraded for it.
Wide Band & extra, better 3-4 clutches.
pricesgarages 10-17-2012 09:24 PM
use the regular on the 1-2 use washers to bring the 3-4 flush with the pin with the plate drilled and pressure regulator spring it will shift firm at heay throttle stock tires on a vortec will bark on the 1-2 at wot but it will be comforable at part throttle use a corvette piston and a .500 boost valve
abbazabba 10-17-2012 09:33 PM
I have all of that done Josh.
That sounds like the kind of ride I'm looking for.
So josh, how would the heavy spring change with the other upgrades in mind?
Will it just make the tires chirp at half throttle too?
Thanks for the input everyone.
pricesgarages 10-22-2012 12:14 AM
the heavier the spring the harder it hits if it hits to hard youll break planetary gears abd or band anchors
