Heavy duty vs Regular Duty - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2012, 07:42 PM
I just don't know which spring will be best.
These two springs are out of a 4L60E Superior Shift Reprogramming Kit. (see pictures)
Heavy Duty and Regular Duty is all the info I have.
Can anyone give me some comparison in shift characteristics in the two?
98 Chevy K1500
5.7 350
4L60E
It's no hot rod but I would like it to tow occasionally.
Has anyone used one of these in a similar set up?
Thanks
Old 10-17-2012, 08:13 PM
SSedan64's Avatar
I'd go with the Firmer HD Accumulator spring for firmer 1-2 shift. On the 3-4 I wouldn't, don't use 4th gear when Towing unless the Trans is upgraded for it.
Wide Band & extra, better 3-4 clutches.
The Following User Says Thank You to SSedan64 For This Useful Post:
abbazabba (10-17-2012)
Old 10-17-2012, 09:24 PM
joshp83's Avatar
owner of Prices Garage
use the regular on the 1-2 use washers to bring the 3-4 flush with the pin with the plate drilled and pressure regulator spring it will shift firm at heay throttle stock tires on a vortec will bark on the 1-2 at wot but it will be comforable at part throttle use a corvette piston and a .500 boost valve
The Following User Says Thank You to joshp83 For This Useful Post:
abbazabba (10-22-2012)
Old 10-17-2012, 09:33 PM
I have all of that done Josh.
That sounds like the kind of ride I'm looking for.
So josh, how would the heavy spring change with the other upgrades in mind?
Will it just make the tires chirp at half throttle too?
Thanks for the input everyone.
Old 10-22-2012, 12:14 AM
joshp83's Avatar
the heavier the spring the harder it hits if it hits to hard youll break planetary gears abd or band anchors
Heavy duty and street strip spinn Transmission - Rearend 1 07-09-2011 11:50 AM
heavy duty springs? ted200008 Suspension - Brakes - Steering 1 06-01-2010 11:46 AM
700r4 rebuild... to go heavy duty or not?? Wac Transmission - Rearend 10 02-09-2010 08:40 PM
heavy duty Thumper_Pumper Suspension - Brakes - Steering 5 05-10-2008 02:00 PM
heavy duty suspension 53belair Suspension - Brakes - Steering 14 01-15-2007 01:16 AM
