Heavy truck front suspensions: - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2012, 01:53 PM
Banned User
Discuss why a heavy duty truck, let's say higher than 1 ton, can not/should not have an independent front suspension.
Old 11-21-2012, 02:31 PM
Wiki Edits: 27
truck suspensions
The problem is that the geometry changes with load on an independent. where would you set the alignment? empty, half way, or to max GVW? I bought an 85 F350 HD that the alignment was set with a big cab over camper. I ran it only partally loaded pulling a trailer, the tires started to scuff and I had to have the twin I beam axles bent to get good tire wear and handling.
Old 11-21-2012, 02:54 PM
Banned
think today they could do it.. with the rig type air bag.. BUT
if a front air bag failed at any speed other than stopped.. with the truck loaded.. it be a mess..
also trucks that big are for work.. and it's K.I.S.S. (keep it simple stupid)
less parts= less upkeep cost..
Old 11-21-2012, 03:55 PM
Banned User
I.c. but what about using a huge macpherson strut type setup? Or double A arms?
Old 11-21-2012, 04:17 PM
Wiki Edits: 27
K.I.S.S. works best.
A long. long time ago double equal a arms were tried but the tire would stay perpendictular but move side to side on bumps.
curious, anyone ever build a heavy truck? darkostoj Hotrodding Basics 5 09-16-2012 04:36 PM
Front and rear suspensions working together ckucia Suspension - Brakes - Steering 8 04-23-2009 10:11 PM
heavy truck trans question propaniac Transmission - Rearend 7 09-08-2004 02:48 PM
independent front suspensions,corvette wheel-7 General Rodding Tech 8 09-20-2003 04:20 AM
independent front suspensions wheel-7 Suspension - Brakes - Steering 2 09-09-2003 01:29 PM
