heavy truck trans question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2004, 09:53 AM
Last journal entry: More propane stuff
I have a manual transmission question.
I recently had a shop in phoenix rebuild an old clark 282 transmission for me. It is out of a f-800 ford. The trans now acts like there is no synchros in it when I downshift from 4th to 3rd. When it is sitting idling I can try to pull it into gear and can feel the synchros. Also when shifting from 2nd into 3rd the synchro usually works. I called the guy that built it and he told me that the synchros had to "break in". He suggested that I gently hold the lever against the synchro for 45 sec for a couple of times. I have tried this and still not right. Any one have any suggestions before I pull it out and send it back.
John
Old 08-24-2004, 02:48 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I would think the synchros should "work" right from the start, and just get smoother from there.
Old 08-24-2004, 05:55 PM
Thats what I thought. I have never heard of breaking in a synchro, but I have only redone a few manual transmissions and they were the smaller new process'.
Looks like I will be pulling the trans.
Has anyone else heard of having to break in a synchro?
John
Old 08-24-2004, 11:46 PM
sbchevfreak's Avatar
Licenced Automotive Technician
nope.
Old 08-30-2004, 08:08 PM
I am getting the transmission back tomorrow. The shop put new synchros in it. Hope it works this time.
Old 08-31-2004, 06:39 PM
Blown79's Avatar
WTH
Yes you were right something is wrong. I run the same tranny in my F-800 and have the same problem from 4th to 3rd ,mine is wore out.
Ed
Old 09-06-2004, 02:30 AM
Old enough to know better
Broken syncro rings are not all that uncommon. I've replace a number in school bus transmissions. If it was a recent rebuild, there shouldn't be any problem. Sounds like the rebuilder gave the old ones an eyeball and said, "Good Enough". He was wrong
Old 09-08-2004, 01:48 PM
Got the trans in week before last and forgot to mention that it works great now.
John
