Hedman Thermal Coated Headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2008, 11:13 PM
Time for new exhaust. A few quick questions.
1. Are the Hedman Thermal Coated Hedders 1 5/8" worth the extra cost? I've read conflicting reviews of them with how the thermal coating holds up. I see that they have the thick 3/8" flanges and 14 gauge tubing as opposed to the thinner 1/4" flanges and 16 gauge tubing. Does thicker flanges and tubing mean better seal and longevity?
2. Are copper gaskets a good investment?
3. Is there any benefit to running 3" exhauast versus 2 1/2"? How about 2 1/2" turned into 3 starting at behind the cab.
4. Any benfefit going to 1 3/4"?
Application is for a 1/2 ton 4x4 SBC around 400 hp.
I guess it comes down to $280 for the thermal coated vs. $150 or so for the thinner, painted ones.
Old 03-05-2008, 07:08 AM
dawg's Avatar
NAVY VETERAN
dead soft copper or dead soft aluminum gaskets hold up much better than composite gaskets.
1 3/4 primaries only help in higher RPM applications
youll do fine with 1 5/8 primaries
3" exhaust provides less restrictive exhaust.
My headman ceramic coated headers lasted for 20+ years since they came out with them and they still look good.
Old 03-05-2008, 08:51 AM
onebadmerc's Avatar
I need a bucket of arc sparks
I don't think a person would want to use a copper header gasket on aluminum heads. I also have been told that the surface needs to be perfectly flat to use the copper gaskets. The aluminum gaskets seem to conform more to surface irregularities, maybe it is because they are made of a softer metal. Since replacing the composite header collector gasket on my 289 with aluminum ones, I haven't had any exhaust leaks.
Old 03-05-2008, 10:12 AM
I've heard people say that they bought them uncoated and made sure that they would fit OK. If they needed a little bending in places they would do that and then send them out to be coated. Since you're putting them in a PU you would probably have plenty of room.
Danny
Old 03-05-2008, 10:26 AM
Good idea. Yeah I thought the 1 3/4" might give me a little more top end without sacrificing any low end torque with the 400 sbc, but I guess not. So the aluminum gaskets are favored over the copper ones? I have heard that Percy's aluminum ones are good.
Old 03-05-2008, 07:23 PM
headman puts a five year warranty on there coating i dont know of any other compay that does that. i think it would be worth the extra cash
Old 03-06-2008, 06:07 AM
dawg's Avatar
NAVY VETERAN
just to give you an idea of the coating longevity here is my hedmanns on my 383 that were on there for 20 years
heres a pic of my new husler ceramic coated headers on my 406
Old 03-06-2008, 08:15 AM
Irelands child's Avatar
I don't have a problem with the Hedman coating. What I do have a problem with are manufacturing flaws with the coating applied right over them. I should have taken before and after pictures of my Sanderson headers. They were totally not acceptable in the 'as supplied' condition for coating until I had ground out pieces of tubing hanging in the exhaust path and many pieces of MIG filler wire. The pieces of tubing were worse where the 4 individual exhaust tubes were welded together at the collector and where they were welded on to the flange. I estimate that it took me 6-8 hours to make these acceptable for Jet-Hot ceramic coating. Interestingly, at two different vendors at NSRA York, including the Sanderson display, I looked inside of already supplier coated headers, the same condition existed - nicely covered with their coating - and Sandersons are "premium" header . Two friends also had the same Sanderson situation with crap similar to mine.
My suggestion - whatever header you do buy, don't have them 'factory coated'. Wait until you are sure they are mechanically acceptable, then send 'em out. Just remember NAFTA - and cheap labor in Mexico which is where many header systems are now being built.
Dave W
Irelands child
Old 03-06-2008, 08:56 AM
dawg's Avatar
NAVY VETERAN
yeah sanderson headers are not as good anymore.
I didnt have any defects in my headman headers even though they were put together by Mexican migrate workers lol.
Old 03-06-2008, 09:15 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If you require fabricated headers, you can't go wrong with Lemon's. Camaroman7d had some made for his pro street project Buick, beautiful work. Then get the coating.
Semper Fi
Ceramic Coated Headers mike bryan Engine 15 09-02-2010 04:47 PM
Can you weld Ceramic Coated Headers? 70bird Engine 2 05-05-2007 09:05 PM
Any experience with Hedman Elite Headers? benwantland Engine 8 08-14-2006 02:45 PM
Curing ceramic coated headers GCD1962 Engine 5 12-18-2005 10:36 AM
Ceramic Coated Headers mike bryan Engine 0 02-09-2004 10:26 AM
