HEI in '73 Monte Carlo - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2002, 05:34 AM
Seon's Avatar
Post HEI in '73 Monte Carlo
Will a HEI distributor fit in a '73 Monte Carlo 350 without having to move the engine forward?
[ November 10, 2002: Message edited by: Seon ]</p>
Old 11-10-2002, 06:27 AM
BOBCRMAN@aol.com's Avatar
Post
yes, but you can't use the factory ign hot wire, it has a resistor in it,you have to run a new 12volt wire to the HEI
Old 11-10-2002, 11:34 AM
MI2600's Avatar
Member# 3287
Post
In my '72 ElCamino (similar to the '72 Monte Carlo), the HEI would fit in but it was against the firewall so I couldn't adjust it. I don't know if they made any changes between that year and '73.
Old 11-10-2002, 04:43 PM
apprentice geezer
Post
IT WILL WORK, HAD A 74 454 MONTE W/HEI, AS PREVIOUSLY STATED NEED 12V SOURCE, TO POWER IT. SUGGEST P/WINDOW RELAY TRIGGERED BY THE IGN WIRE.
Old 11-10-2002, 04:58 PM
Seon's Avatar
Post
Thanks for the replies. I'll do as suggested and will post with results.
