HEI Big Cap to Small Cap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2006, 09:53 AM
Last journal entry: Oil Leaks and Nobody said look for ...
Hi Hotrodders,
I have a TPI system from a 1986 Camaro that came with the big cap HEI computer-controlled-advance distributor. The big cap is one of those that has screws(not the L-hooks) holding down the cap to the distributor. One of the screws is seized and broken off.
This system is going on a Small Chevy that is being swapped into a Jaguar XJ-S. I see this as an opportunity to go ahead and change to the small cap distributor considering the additional clearance I can get with the small cap distributor.
I have read that the connections are different between big cap and small cap distributors. I have heard that there are adapters available to make this swap work. I am asking the group for a source on these adapters and any other things I should be on the lookout for on making this change.
Thanks in advance,
Ericbr
1986 Jaguar XJ-S
355 ci SBC
Old 12-18-2006, 05:04 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Goggle "Daves Small Body HEI's" he should be able to help and provide the parts required to rebuild the Distributer.
Doc
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 03:36 PM
stock HEI to Small body HEI now there's problems, need help Doc fat50chevy Electrical 6 07-13-2006 03:19 PM
small block or big block southrncuz1816 Engine 16 03-19-2006 07:40 PM
Small vs big chevy interchange? zachscc Engine 3 12-10-2002 02:29 PM
Small Block 400ci...or...Big Block 396ci???? chevyelc81 Engine 17 10-05-2002 07:06 AM
