Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hei coil heats up no spark
Old 10-11-2008, 05:30 PM
Jmark's Avatar
Jmark Jmark is offline
Hmm, the Mallory is a stock replacement HEI. There is a wiring harness that comes out of the base of the dist. and plugs into the cap. That plug has, I believe, Red, Black and Brown. NO other wires should be attached to those 3 wires. There should be another wire coming from the ignition switch that plugs into the "+" spade on the cap. The "-" spade is for a tach hookup.
