Hei coil heats up no spark - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2008, 02:40 PM
Hi all,I installed a Mallory 85 Hei dist the coil heats up but there is no spark.Any ideas thanks.
Old 10-11-2008, 02:45 PM
Pull the coil and check ohms on the circuits as per Mallory specs. IT might be shorted, etc.
Old 10-11-2008, 03:33 PM
Ok,put another coil in it and it instantly heated up to the point you could not touch it.
Old 10-11-2008, 03:40 PM
Jmark's Avatar
Then I'd say you have power to one side of the coil and the other side is grounded, ain't gonna work that way! LOL
Are you plugging in the correct wires onto the correct terminals? Sounds like you've got something backwards.
Old 10-11-2008, 03:58 PM
I have blk to blk red to red and yellow to yellow, Power source is hooked to the red.
Old 10-11-2008, 05:30 PM
Jmark's Avatar
Hmm, the Mallory is a stock replacement HEI. There is a wiring harness that comes out of the base of the dist. and plugs into the cap. That plug has, I believe, Red, Black and Brown. NO other wires should be attached to those 3 wires. There should be another wire coming from the ignition switch that plugs into the "+" spade on the cap. The "-" spade is for a tach hookup.
Old 10-11-2008, 06:36 PM
T-bucket23's Avatar
Wiki Edits: 26
Do you have the power wire connected to the TACH terminal by any chance.
Old 10-11-2008, 06:53 PM
Check Ground Strap In Cap For The Coil.. Poor Ground Coil Run Hot Fast...
Old 10-11-2008, 09:36 PM
The wires are in right,I'll check the ground
Old 10-11-2008, 10:11 PM
If the coil is connected to the distributor there is no power to the coil wire.Now I hooked the coil up to the battery not the distributor and there is power to the coil wire. Would that indicate a bad ground in the dist?
Old 10-12-2008, 08:36 AM
I had the module tested at Autozone,and that was the problem. It works now
Old 10-12-2008, 06:14 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Just make sure you added silicone thermal grease under the module. It makes it easy to transfer the heat the module produces. The modules in a HEI are known to short because of heat.
Chevy HEI - Weak Spark daveturnbull Electrical 5 07-25-2011 09:58 AM
external coil for hei info needed stevej068 Engine 1 03-25-2007 11:52 PM
blazer has spark at coil and gas no spark at plugs ricksautorestoration Engine 29 02-15-2007 08:30 AM
MSD 8365 HEI, no spark after setting rev limiter bracketeer Electrical 8 08-14-2006 07:37 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
