HEI Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2009, 02:03 PM
HEI Conversion
I have a 66 corvette that I am looking at converting over to an HEI distributer system. I have the new HEI distributer with the coil on the top of the distributer cap. My issue is, ideally I would like to use the original external coil to keep more of a factory look. Is this possible and if so how would I go about doing it.
Thanks in advance
Old 10-30-2009, 02:18 PM
SSedan64's Avatar
HEI Conversion
You could use an electronic conversion kit in your stock points distributor, change the points coil out with one that looks just like the stock one but, has higher output for elecronic ignition. Pertronix, Accell etc.. make the kits, I think some work with the stock coil also. Or use a Small cap HEI that use an external coil.
HEI conversion Info>> http://rmcavoy.freeshell.org/HEI.html or http://www.oldengine.org/unfaq/hei.htm
Pertronix conversion>> http://www.chevyhiperformance.com/te...stributor.html
Distributor Install>> http://www.corvette-restoration.com/...stallation.pdf
Other good Tips from corvette-restoration.com>> http://www.corvette-restoration.com/...hnical_papers/
Old 10-30-2009, 02:20 PM
T-bucket23's Avatar
Wiki Edits: 26
I dont think it would be possible to use a large cap hei with an external coil. The small cap HEI can be used with an external coil but requires a little more wiring.
Make sure you feed the HEI with full battery power. You car has a resistor wire for run mode which will drop the voltage to around 9 volts. The HEI will not be happy with that.
Chet
Old 10-31-2009, 03:16 PM
fast68's Avatar
likes chevy trucks & boobies
use a stock hei they are dirt cheap
all you have to do is run a 12 guage wire from an ign source
fuse panel has a couple
simple
done
i dont knwo why some ppl like to try to make things more complicated than they need to be with aftermarket garbage etc
Old 10-31-2009, 03:37 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Get the petronix ignition i have used it several times and it really work great, You will have electronic ignition wit the appearance of the stock parts, You will be able to use your stock distributer / stock looking cap and wires and the old style looking coil. http://www.cbsperformance.com/ignitor.shtml . ....Cole
Old 10-31-2009, 04:17 PM
Accel used to sell a replacement coil cap for the traditional HEI that eliminated the coil and provided a conventional center terminal for use with an external coil. Of course, a large cap HEI isn't going to look anywhere near stock whether you have an internal or external coil.
Old 10-31-2009, 08:04 PM
life is a temporary assignment
Yes you can do it... with the large cap HEI. But you have to buy this to be able too...http://www.jegs.com/p/MSD/MSD-HEI-Ca...47893/10002/-1
But it would look nicer if you take a point's dist, And put a petronix kit in it..
1967 SBC 327 HEI Conversion BowTiePride Engine 16 07-03-2009 11:44 AM
HEI Conversion? HotRodMan Electrical 7 08-28-2006 10:55 PM
Unilite to HEI conversion 7dcrzr Engine 3 02-01-2006 11:15 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
hei conversion limey Electrical 3 01-02-2003 11:23 AM
