Hi,
The resistance is built into the wire, don't use it, use a new 10g wire from the starter solenoid to the bat. terminal on the dist. cap, that's it, don. Rich |
Hi: I'm going to move this thread to the Electrical section.
Dan
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
If I understand this correctly I need to run a new wire from the post on the solenoid to the BATT terminal. I already have the battery cable and the piggybacked wire I mentioned earlier that runs to the alternator as well on the same post. So I will have 3 wires on the post of the solenoid? Is this correct? Thanks
You need a hot wire that is switched on/off (usually coming from the ignition switch) directly to the BAT terminal on the HEI cap. No resistor wire with GM HEI! No ballast resistor with GM HEI! If the wire is not connected thru a switched source you will have no way to shut it off. Wiring directly from the starter solenoid will make the ignition "ON" all the time.
Chet |
HEI Conversion
I don't know if you got an answer to your satisfaction on converting to HEI. But this is a good site with plenty of explanation and tips. Others may have the same questions.
http://www.oldengine.org/unfaq/hei.htm |
| Points to HEI conversion; wiring issue?? | VI009DZ | Electrical | 11 | 06-11-2007 06:56 PM |
| HEI Conversion? | HotRodMan | Electrical | 7 | 08-28-2006 10:55 PM |
| Unilite to HEI conversion | 7dcrzr | Engine | 3 | 02-01-2006 11:15 AM |
| HEI wiring diagram | oz_vette | Electrical | 2 | 08-13-2003 07:54 AM |
| ??I NEED HELP WIRING 2000 S-10 CONVERSION | Luap | Engine | 0 | 12-09-2002 04:43 PM |
