HEI Dist. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2012, 11:12 AM
HEI Dist.
I have a 84 C-10 350/350 stock engine , newly rebuilt. The engine has a slight miss and time for either a rebuild on the dist. or a new one. The one I have now has many many miles on it.
Not sure if I should rebuild the one I have or if maybe you guys have seen a good deal on a dist thats new? It is a stock rebuild but I would like a dist thats "blue printed" for the engine.
What are my options?
Old 04-20-2012, 01:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If your distributor still has tight bushings and the advance weight pins aren't worn, your distributor can be used. Unless it's a computer controlled HEI, it'll benefit from a performance curve set up for your particular engine/vehicle- as will all distributors, just some are easier to modify than others.
If your HEI is too far gone (and it's not computer controlled), there are new eBay HEI distributors for under $50, I cannot say what the module is like so to be safe, if using a cheap distributor like that, replace the module. Summit and Jegs, etc. have any number of aftermarket distributors to choose from.
This has been covered numerous times here, you can do a search for more. Also there's a page here w/info that may help you.
Old 04-20-2012, 04:51 PM
whew, so far accel is junk, ebay are hit and miss, MSD hei made in china possibly same as e-bay.
Old 04-20-2012, 05:46 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
For a discount new unit Check out skipwhiteperformance for a deal on a decent HEI 6500R. The "blue printing" is not some thing that is needed with these. What is needed is setting up the limits on the mechanical and vacuum advance. Get a vac adv limiter plate from crane and you can use a machine screw to limit the mechanical adv. Yes there are many threads on the subject.
Lots of things are made over seas and still perform OK, lots of things also don't. I personally know a few of the skip Asian HEI's are in action, all have gone for years without a hitch. if you must then buy American nothing wrong with that either just reach a little further down in the pocket.
Testing Hei Dist. roundman101 Electrical 8 06-14-2011 04:31 PM
MSD an HEI Dist. Bowtie man Electrical 3 04-05-2008 08:44 PM
need hei dist. tree20 Engine 1 10-24-2006 02:01 PM
HEI dist. mods. Rob85K10 Electrical 3 01-10-2003 06:06 PM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 02:38 PM
