HEI dist in 57 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2012, 04:20 PM
warren57's Avatar
I installed a new GM crate engine. It has an HEI dist. which is much larger than an older style with external coil.
Removing the dist to prime the oil pump will be quite a challenge and in fact may require pulling it part way.
Is there any alternate ways to prime the oil system. I was thinking something like attaching an external oil pump to a remote filter kit and pumping oil through the engine.
Has anyone tried anything other than spinning the oil pump through the distributor hole???
Thanks
Old 07-12-2012, 05:00 PM
ericnova72's Avatar
More for Less Racer
Do a search for "engine pre-luber" or "pre-oiler", should come up here at Hotrodders and on Google.
Works like a pressure pot painting set-up. Hot Rod or Car Craft had an article on making one a while back IIRC.
Old 07-12-2012, 09:50 PM
RWENUTS's Avatar
Yup not much room for priming after the motor is in. Made the same mistake on a 56 Nomad my buddy owns. We used an old distributor to drive the pump. Left the gear off the bottom and stripped weights etc off the top. Had a round stub left on top. Used a 90 degree adaptor for our drill to drive it with. Worked well enough to get oil up to the rockers. Here's a link for a similiar one. Available at hardware stores.
Right Angle Drill Attachment
HEI Dist. Catfish11 Engine 3 04-20-2012 05:46 PM
MSD an HEI Dist. Bowtie man Electrical 3 04-05-2008 08:44 PM
need hei dist. tree20 Engine 1 10-24-2006 02:01 PM
HEI dist. mods. Rob85K10 Electrical 3 01-10-2003 06:06 PM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 02:38 PM
