hei dist position - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2008, 06:56 PM
hei dist position
I recently changed from a non vacuum dist to a hei unit . The car starts and runs good,but I'm taking the dist out to have it set-up on a machine. What I want to know is should the coil be prety much in line (parrallel) with the firewall? Mine is at almost a 45* angle and just doesn't look right to me . When I put it back in can I turn the oil pump rod and set the dist down in a different set of teeth as long as the rotor is pointing at #1 on the cap?
Old 08-03-2008, 07:01 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Yes, as long as you have enough adjustment on the dist...
If the HEI has a vac unit, it sometimes limits where you can go with the different teeth...if that makes sense
Old 08-03-2008, 07:03 PM
Greg T's Avatar
www.krusinklassics.net
You can clock it any way you desire. You only need to be concerned about getting the timing and firing order right.
Old 08-03-2008, 08:54 PM
with the #1 cyl on compression stroke and timing marks lined up at 0 where is the normal position for #1 plug wire after the dist is completly seated before advancing ?
Old 08-03-2008, 10:10 PM
Greg T's Avatar
Anywhere you want it to be. Wherever it is convenient for your installation. I like mine in th back on the driver's side because it fits my wire looms better.
Old 08-03-2008, 10:32 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I always set them up so the wires coming out of the distributor body are at the 6 o'clock position, in other words directly in a straight line to the center of the hood.
Old 08-04-2008, 08:41 AM
Frisco's Avatar
Glad To Be Here
You can make the #1 location at any position you wish. Then place the rest of the wires in the cap following the firing order in a clockwise direction. Below is a diagram of the "stock" location for reference. Left click on it for a larger view.
Pro comp Hei dist t/a clone Electrical 3 04-29-2007 04:20 AM
HEI mallory dist ?????? weedhopper Electrical 5 08-21-2006 08:53 PM
Mallory 85 Series HEI Dist. Houman SS '70 Engine 4 05-11-2005 01:49 PM
HEI dist. mods. Rob85K10 Electrical 3 01-10-2003 07:06 PM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 03:38 PM
