hei dist wiring help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2008, 03:24 PM
Calling all "Vette" owners!
I wonder if any of you folks can help? I'm currently in the process of fitting a 350c.u. SBC from an 81 Corvette C3 L82 (the last of the carburettor model) to my '50' Chevy pick-up.
The problem is I never saw the car it was removed from. It has an HEI dizzy with electronic ignition. It is not the computer controlled unit.
The cap has 2 connections.... 1 for the tach and 1 for the 12v feed.
On the body of the dizzy itself are 3 wires going to a block connector.Do I need a control unit? My Haynes manual is a bit vague as to what they are. Can any of you "guys" shed any light on this! I am going nuts trying to get this running!
Any advice would be welcome!
Thanks in advance
Old 05-25-2008, 03:41 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
That 3 wire connector plugs into the cap right behind the tach and 12 volt power connections.
Old 05-25-2008, 03:42 PM
thanks for the quick response.
Mallory 85 Series HEI Dist. Houman SS '70 Engine 4 05-11-2005 01:49 PM
HEI Wiring Please help 64novaboy Electrical 3 10-16-2004 04:49 PM
HEI wiring question The Vandal Engine 2 03-27-2004 03:45 PM
HEI wiring diagram oz_vette Electrical 2 08-13-2003 08:54 AM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 03:38 PM
