HEI distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2008, 06:22 PM
HEI distributor
Is an HEI coil a good adder to my new 65 mustang. I had a mustang several years ago and put a Mallory Unilite on it but since then HEI distributors became much more affordable. My questions are as follows.
1. Is an HEI Distributor going to add to the driveability ofthe car?
2. Does an HEI distrb. improve gas mileage?
3. I there a particular brand I should buy and brands I should stay away from?
Old 11-14-2008, 06:01 PM
HEI is intended to do 2 things, the first is to light off lean emissions mixtures at idle, or in other words reduce miss-fires that cause high levels of unburnt HC emissions. The second thing is to meet Federal and California requirements for Mean Time Between Tune-ups, or remain stable and effective in the face of little to no customer maintenance of the ignition system and spark plugs.
Fuel mileage will not be effected unless your current system miss fires enough to result in poor or missed burns which results in unused energy going out the exhaust instead of providing a push on the crankshaft.
The brands of conversions and replacements on today's market are all sufficiently good for a street engine. The big thing it buys is freedom from points and condenser replacement.
Bogie
Old 11-14-2008, 11:21 PM
JeffB's Avatar
Ford HEI
I have one in my 302,it's doing a fine job and I really like the one wire hookup and the extra clutter that it eliminates.
Old 11-15-2008, 08:55 AM
Thanks guys, I am going to go ahead and get one. I don't want to mess with points and I am required to do an emissions test when I go from antique plates to daily driver plates which will happen this spring.
Converting small chevy distributor to HEI bbcwgn Engine 2 11-28-2006 03:46 PM
hei distributor hookup help meev182 Electrical 11 07-07-2006 03:35 PM
New GM hei distributor quit. HELP fouroheight68 Engine 16 02-15-2005 06:30 PM
Mallory HEI distributor overlap Electrical 5 02-20-2004 07:45 PM
69 Pontiac Firebird HEI Distributor Question pontiac69 Engine 13 12-01-2003 08:35 PM
