Machanical advance does not work at idle, it`s only use is off idle, centrifical force is what advances it. Connect the vacuum advance to a full time manifold vacuum port, one that pulls vacuum even at idle. Since you already had 12 degrees base timing, the vac advance will add another 10 to 12 degrees depending. After you connect it, recheck the base timing, it should be 20-24 degrees.
The springs don't regulate how much timing you get, they regulate at what RPM the timing advances. You need to use smaller pins or longer slots in the mechanical advance to get more timing. The vaccum advance should only come in in high vaccum situations such as cruising on the highway, usually to give you better gas mileage.
Here we go again. Many ask why do you need vacuum advance at idle?
I used to ask that same question. You need it because idle and off idle mixtures are lean, leaner mixtures burn slower, and when the mixture burns slow it needs more spark advance to compensate. Manifold vacuum works off idle just the same as ported vacuum. However, since the idle mixture is lean, it needs that extra spark advance when coming off idle to the main circuits, if not the engine will sometimes sputter. You have to remember, the power valve doesn`t kick in until the vacuum drops under a certain vacuum limit, during regular driving you won`t open the throttle enough to make the vacuum drop low enough for the power valve to enrichen the circuit so the mixture is still lean. Take any chevy vehicle from the mid 70`s to early 80`s. The catalyst says "timing set with vacuum advance disconnected and plugged" if it`s connected to a ported source there is no need to disconnect it, because it doesn`t pull vacuum at idle. When I ran my small block to a ported source, a mild 9:1 compression 350 with headers, small RV cam, intake and carb with 3.23 gears, it wouldn`t even spin a tire from take off, it was a dead player. For a long time I couldn`t figure out why it was so sluggish, until a member of this site told me to connect my vac advance to a manifold source, I did as he asked and the car felt like it picked up 50 horses. It had great bottom end torque and throttle sensitivity. |
set your base timing by posotion of the distributor
use vacuum advance if you need more advance at higher rpm it uses a ported vacuum source on the carb mechanical advance also works at higher rpm alot of times i dont use vac advance, i dont even connect it, especially on stock cam engines, as they run perfectly fine without it and get plenty enough advance from the mech weights already to run fine. overkilling ignition advance will cause problems quicker and worse than not having enough . due to detonation/pinging from over advanced timing use a timing gun to figure out your base timing and to see how much your advancing at what rpm levels too much of it is the worst thing to have.,, |
| HEI Distributor, no spark think I tried everything | bradster79 | Engine | 14 | 07-25-2011 10:06 AM |
| lots of aluminum corrosion in stock HEI distributor | fast68 | Engine | 1 | 08-31-2009 04:42 PM |
| Converting small chevy distributor to HEI | bbcwgn | Engine | 2 | 11-28-2006 03:46 PM |
| HEI distributor and TPI | 70bird | Engine | 7 | 04-19-2006 10:10 PM |
| HEI distributor - Which one? | Eagle1 | Engine | 5 | 07-28-2004 11:46 PM |
