HEI Distributor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2013, 03:35 PM
HEI Distributor?
Bought another project, car runs good but when running down highway car loses all electrical to I'm guessing the HEI. Engine quits running, and won't fire for about 5 mins. then starts up and runs again. Any Idea's? Car is a 47 chev with a 327
Old 05-28-2013, 03:37 PM
Banned
module or coil going out, very common with cheaply made modules and coils.
Old 05-28-2013, 04:59 PM
thanks I thought thats all it could have been, but Ive chased my tail a few times with electrical lol
Old 05-28-2013, 05:25 PM
sedanbob's Avatar
Make sure the power lead is securely attached. I hooked mine up with a flat blade connector which was fine for a few hundred miles then started coming loose. Everything would run fine then just shut off like I had turned the key. It would re-start, then a few minutes later shut off again. The stiffness of the wire was the only thing keeping it close enough to arc, until it warmed up. I replaced the blade connector with the OEM style that locks into the HEI housing.
Hei distributor help please .... Dirtdolla Engine 2 04-17-2012 04:07 PM
How do you remove the distributor gear on an HEI distributor? against all odds Hotrodding Basics 4 01-31-2012 09:58 PM
Which GM HEI distributor? Madmax305 Engine 8 08-23-2010 08:34 AM
HEI distributor rottenralph Electrical 3 11-15-2008 08:55 AM
HEI Distributor jeff germano Electrical 0 12-01-2002 03:59 PM
