HEI Distributor on a 289 V8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2008, 04:45 PM
I sent one thread out but, i don't think it was understood. I put an HEI distributor make for my 289 V8 on it and i have the engine at top dead center but, i cannot get the rotor to point toward the number 1 cylinder. The bottom of the distributor with the slot in it will not match up with the part that goes into the slot when i put the rotor in the right position to point to the number one position. Can anyone tell me how to get the slot to line up with the oil pump rod and get the rotor to point in the right direction. Thanks Ron. I need the help. I cannot get my baby started.
Old 08-25-2008, 04:58 PM
nitro_baller4692's Avatar
floppers forever
it should have a 5 1/16'' hex drive for the oil pump.give it a slight turn in the direction you need to go.it should drop in.
Old 08-25-2008, 05:01 PM
JeffB's Avatar
HEI Ford
Something does not sound right your distributor should not have a slot, the oil pump shaft on a Ford is a 5/16" hex.Look at the bottom of the gear on your old distributor and compare them and see if they are the same.I have an HEI in my Ford 302 it went in easy.Is this HEI new? maybe it was misboxed.See if you can post some pics of it.
Old 08-25-2008, 05:56 PM
FEDDO's Avatar
there is an adapter that converts from the chevy type drive to the ford. super glue it in place. it works.
HEI Distributor on a 289 V8 Ronald J Berry Sr Engine 2 08-19-2008 06:39 AM
Camaro V6 to V8.. anyone ever done it? C10 Engine 3 11-23-2007 01:12 PM
Bigger Engine For 68 Falcon Jim69Mustang Engine 4 10-07-2007 08:08 PM
Ford V8 289, which is which calimstng66 Engine 2 04-17-2004 07:55 AM
starter wireing 289 ford v8 jamesbiggg Electrical 1 08-06-2003 05:10 AM
