Will a Chevy 350 HEI distributor will clear the firewall of my 55 Chevy
If it's a 350 motor in a 55', I've seen it done but you won't be happy. The motor needs to come forward 3/4"+ or bend the firewall. Moving the motor is best. What dist. is in it now and what is your goal? |
Hei
TRUST ME MSD IGNITION IS THE ONLY WAY TO GO.
Doc here,
It's been a long, long long time...... But as I remember, In the stock mount location for the engine..No It wont clear, or be VERY close.. I had problems in the past (even with a stock 283 Dizzy) where the motor mounts would break or stretch the engine would rise on the right side sending the Dizzy cap into the firewall, This would Flex (but usually not break) the cap, just enough to nick the tang of the rotor..Net result ....KBOOM...and no run no more..(untill I got the spare rotor out of the glove box and installed it..) First line of defense in those days was Weld the mounts with a Chain tightly between them..Myself (ON MY 57 because of the dash layout) dumped the glove box, cut a hole in the firewall, and built a Sheetmetal box to fit between the Glove box and firewall and cradle the dizzy.. Being the lazy guy I am, I could service the dizzy through the glove box, while sitting down...A plus on rainy days! What did I know, I was seventeen, thought the car should always be noisy, smell like a refinery inside, and be warm anytime the engine ran...That was the definition of a FAST car back then...Right? That and if it had baby moons, and glasspacks..and a RAKE.. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Like already said........NO ......if the engine is in the stock location. BUT..... if it was installed with a side mount engine kit.......YES....it could. Most of the kits I have seen to install a SBC into a 55 - 56 - 57 Chevy moved the engine forward....just for that very reason. When I installed a Big Block Chevy in my 55, years ago....I moved it forward almost 1 inch and made side motor mounts and a transmission mount to go under the transmission ( like the later model Chevy ) ... Like tiresmoke55 said....a MSD distributor is well worth the investment. I installed one in my 40 Ford with a 283 Quick and easy solution....because I could NOT move the engine forward.Deuce... . |
A stock HEI, as stated, move this, beat the heck out of that, destroy the firewall, etc.
NOT AN AD, just FYI, a small body, real, live HEI IS available, as a conversion done to YOUR stock points dist. NOT a PerTronix, but a real HEI. How do I know this? I invented, and convert points dists to the small body HEI. Be wary of the Ready to Quit MSD distributors as their modules, which are NOT HEI level output, and the RtQ modules are mounted in the center of the dist, The distributor has to come completely apart for change, and it is soldered to the pickup. Do that by the side of the road. Take your Cold Heat battery powered soldering iron with you if you use one of these dists. |
Distributor mod
Distributor
I am running a 66 Corvette point distributor with mechanical tach drive. I don't want points anymore. Pertronix is an option since standard HEI won't fit. I am up for suggestions.
If you would give me a real e/mail address, I will send you pics. As I said, this IS NOT AN AD, SO....off the board, please.
As far as I am concerned, PerTronix ISN'T an option, it is a junker setup that needs removal. Want a real ignition system for the Corvette, you have two choices, my small body HEI conversion for the tach drive dist, or MSD tach drive dist (or one of my MSD trigger dist conversions to the Corvette dist), and 6AL or digital 6 series MSD box.
| whats the difference between 55 and 56 chevy pickup? | mile-hightoyz | Hotrodding Basics | 8 | 08-13-2011 09:33 AM |
| Attention: Willing to trade a *********for 55 buick or 48-54 chevy... | DeathByGreaser | Hotrodders' Lounge | 5 | 10-23-2009 08:49 PM |
| 55 chevy hood measurements | larry g | Hotrodding Basics | 1 | 11-28-2004 06:35 PM |
| 55 chevy 3 on the tree to a SBC 350? | mile-hightoyz | Transmission - Rearend | 8 | 02-23-2004 09:57 AM |
