Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HEI Distributor and Alternator, ford 460
Old 11-06-2012, 01:52 AM
lil-vulky lil-vulky is offline
Uploaded with
Uploaded with
ok so That little red wire was the wire that went to my normal distributor but it doesnt works with the hei and doesnt get power when ignition is on? the yellow wire is the wire thats coming off my hei distributor. also that blue wire off the solinoid is going to the starter motor
the alternator picture is my alternator and external regulator but 1 wire from the regulator i havent found an ignition switch to hook it upto, but how can i test my alternator works? coz when i put a volt meter on it the alternator doesnt show any volts at all not sure how to test it
