HEI distributor with Autometer tach problem
Sorry if this has been posted before, I did a quick search and didn't find this posted. I have a '72 Chevelle 454SS. When I bought the car the factory tach wasn't working. I assumed it was just broken. I bought a new Autometer 3900. I wired this bad boy up and ...... nothing. Light works, but needle doesn't work. It is wired correctly. I have played with the connector, taken the cap off the top of the distributor and the yellow ground wire to the tach connector looks fine and intact. I assume it is grounded fine because the light works? I'm stumped, would a faulty coil cause something like this? Car runs great, just not tach. Any suggestions? Thanks in advance!
I guess I should have said the yellow negative wire from the coil. It is the one that says tach on the cap. Really making me scratch my head. It is really simple. Should work, but doesn't?
This is a picture of the type of coil. Hooked green tach wire to end prong on yellow wire. Is that right? It says tach on it?
Yeah, I checked the wire. It seems intact. I am new to this stuff, so please bear with me here. Could I have the wrong coil in the distributor? Would that cause both tachs not to work (factory/autometer)? Do you think replacing the coil would solve the problem?
It sounds like you have it wired right, so maybe its time to buy a new coil. A stock Delco coil is fairly cheap to purchase, and it will work fine with your vehicle. You don't need to go for anything expensive in aftermarket ignition parts.
If that tach terminal is working, it should also show a reading when you attach a a tach-dwell meter. If you can borrow a meter from someone, you could verify that you are getting a tach signal on the terminal. Bruce |
Sounds like it's wired correctly
Is the green wire terminal at the coil making good contact? I’d do a continuity check from the other spade connector on the yellow coil wire and the green tach wire just beyond the coil connector and again at the tach if no continuity …….. Might try running a temp wire in from the window from the coil to the tach and eliminate the green wire......do you know anybody you could try a swap with..... that would eliminate the coil. |
Changed out coil a minute ago and....nothing!
Try the continuity check from one end of the tach wire to the other end. There has got to be a short in there somewhere. Try running a jumper from the coil to the tech..... eliminating the green wire altogether
Red - Ing (fuse box) also ran off Acs (fuse box)
Black - Chassis ground White - Headlight (fuse box) Green - Tach terminal (though connector also ran clamped directly to prong on yellow wire) |
Green wire coming in from right side saudered to brown wire attached to tach terminal
Sorry pic is so small |
Just bought a tach filter online. That would be way too easy if it worked. Probably won't, how is that for pessimism!
| AutoMeter Tach 439-8 & Rev Limiter 452 | Phils2888 | Electrical | 0 | 11-12-2010 04:34 PM |
| I need help installing my autometer tach. | Olds86 | Electrical | 9 | 03-16-2009 11:12 AM |
| Autometer gage problem | bentwings | Electrical | 4 | 11-17-2008 08:30 AM |
| msd distributor vs mooneyes tach problem? | bob myers | Electrical | 3 | 07-01-2007 03:55 PM |
| Autometer Tach Wire??? where does it go? TBI | boneyard Buick | Engine | 5 | 09-29-2006 12:23 AM |
