HEI Distributor cap and rotor question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2013, 07:49 PM
So when i was dropping the v8 into my s10 i broke the rotor on the distributor (cap was removed) so my question is, do all HEI distributors use the same cap and rotors? Coil located in cap
Old 06-17-2013, 08:02 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
more info please
GM hei dist. are generally the same physical size but there are levels of quality.
OEM, high performance coils and foreign made junk.
Why do you ask?
vicrod
Old 06-17-2013, 08:10 PM
I was just making sure i got the right rotor, the distributor is made by TSP, and i was just wondering if say an accel cap and rotor would be the same
Old 06-17-2013, 11:02 PM
vicrod's Avatar
life is a ride
not aftermarket
I assumed that you were referring to GM hei products or OEM replacements.
Can't tell you about aftermarket stuff.
vicrod
Old 06-18-2013, 02:24 AM
Just make sure you don't get the low grade cheap stuff, ask for brass pole cap and rotor. The cheap **** have aluminum poles, corrode quicker!
Old 06-18-2013, 03:14 AM
Banned
Accel makes a cap and rotor kit , it has brass terminals
as long as you get one for a chevy v8 engine and not any other
make (olds/catty/etc)
#8122 is tan # 8123 is black cap.
cap +rotor with brass kit
Old 06-18-2013, 08:31 AM
Every GM factory style V8 HEI uses the same cap and rotor.
Old 06-18-2013, 08:43 AM
Banned
ok, devoiced coil hei.
distributor, hei, question, rotor
Mallory HEI Distributor Cap Replacement 64Joker Electrical 1 03-26-2011 01:29 PM
Distributor Cap/Rotor Contact Point Burning? Grouper Engine 9 05-18-2008 07:43 AM
Distributor Cap Question Blazin72 Engine 3 12-29-2005 06:10 PM
Rotor cap problems WakBordr7387 Engine 6 12-04-2004 08:46 PM
HEI in-cap coil wiring question BlueByU Engine 2 05-29-2004 12:19 PM
