Hei distributor help please .... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2012, 08:54 PM
While changing curve advance weight one of the prongs that hold center weight broke now when I took dist apart that piece is actually a collar with a crown I'm assuming is the relucter .....question is can I replace just this collar and where to find it I think its called an advance head
Old 04-17-2012, 12:11 PM
SSedan64's Avatar
Have someone Tack Weld the Post back in place, both while you're at it.
http://www.autozone.com/autozone/rep...00c152800834e1
Old 04-17-2012, 04:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I doubt it's sold separately. The suggestion of fixing your broken one might be the simplest way to go about it, although I would think finding another HEI core wouldn't be too hard.
In any event, I wouldn't spend too much to fix it- there are HEI distributors brand new that can be bought for <$50 plus shipping. If you have a good GM or aftermarket module, toss the one from the new distributor, install yours w/heat sink compound and call it good.
How do you remove the distributor gear on an HEI distributor? against all odds Hotrodding Basics 4 01-31-2012 09:58 PM
HEI distributor help 72c10chevy Engine 11 12-24-2008 06:02 AM
hei distributor aceofspades49c Engine 8 05-01-2006 01:06 PM
HEI Distributor wally Electrical 4 05-18-2004 03:36 AM
hei distributor?? malibuman Engine 3 10-27-2003 08:21 PM
