HEI distributor noise ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2011, 12:42 PM
Aloha Chevy's Avatar
Aloha,
I'm curious, what kind of sound should my HEI distributor make that is normal? I think that mine is O.K. and works fine, but am curious about how it sounds. Mahalo, Al
Old 10-19-2011, 01:34 PM
SSedan64's Avatar
It shouldn't make any sound.
Your Rotor may be rubbing inside the Cap. A quick inspection will tell the tale.
Old 10-19-2011, 01:36 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 i was thinking the same thing.
Cole
Old 10-19-2011, 03:12 PM
Aloha,
I was kind of thinking that. The cap seems a little loose and poor fitting. It's new. I will peek under there and see whats up. It makes a light humming sort of sound. I have another cap, I'll swap it out and see what happens.
Mahalo
Old 10-20-2011, 01:20 AM
Aloha,
I checked inside there and everything seemed fine. Nothing wrong. I changed the cap, still some noise. Runs good, not loud, just a whirring sound. I can live with it. Mahalo, Al
Old 10-31-2011, 06:05 PM
noisy distributor
Aloha,
Summit HEI out, GM HEI in. Problem solved.
Mahalo
Old 10-31-2011, 06:08 PM
eloc431962's Avatar
Wiki Edits: 37
Originally Posted by Aloha Chevy
Aloha,
Mahalo
Excellent glad you fixed it and posted back.
Cole
Old 11-03-2011, 05:30 PM
Some cheap HEIs have crappy bearings that usually poop out pretty quickly.
Old 11-03-2011, 09:19 PM
Thrashing machine
Aloha,
I have learned from experience that new parts are not always the same as good parts. Al
slight humming noise at idle and knocking? noise on slow acceleration zoomo Engine 13 05-26-2011 10:00 PM
86 454 noise? JoeMo Engine 6 09-22-2010 09:07 PM
pop noise tomthecomic Transmission - Rearend 5 10-07-2007 07:16 AM
noise in third Turbo Terror Transmission - Rearend 0 09-21-2006 09:40 PM
noise jwash56 Engine 2 09-15-2006 07:19 PM
